XML lookup with QRZ
#1 Posted : Friday, November 13, 2026 2:20:45 PM(UTC)
Hi Dennis...lately I'm seeing this error when the callbook window does an auto lookup on QRZ. "Error opening http://www.qrz.com/xml/c...c11feafd&html=FR5CN
OLE IDispatch exception code 0 from msxml6.dll: The HTTP redirect request failed "
This is the response I received from a QRZ trouble ticket, which means absolutely nothing to me:
"<p> You should be using the HTTPS endpoint, not HTTP.&nbsp; For some reason your system is refusing the redirect which would handle the change automatically.&nbsp; You need to update your XML endpoint manually as a result.</p> <p> &nbsp;</p>"
So, is this a LOGic problem, or a QRZ problem?
WN4AZY on 11/16/2026(UTC)
#2 Posted : Friday, November 13, 2026 6:56:51 PM(UTC)
Same error I get but not on all calls
#3 Posted : Friday, November 13, 2026 11:40:35 PM(UTC)
Same here, Allen, some go through no problem.
#4 Posted : Monday, November 16, 2026 5:07:51 PM(UTC)
Happens here too. Looks like a nuisance error. I still get the data.
All the error means is that I should be going to https://xmldata.qrz.com/xml/current instead of http://xmldata.qrz.com/xml/current
I don't know why everyone on the internet is suddenly so anal about encrypting publicly-available data.
Will fix it! Thanks.
#5 Posted : Monday, November 16, 2026 5:45:31 PM(UTC)
Or maybe I won't fix it. Here is the XML he is sending back:
The first request. All looks good:
.oXML.Open("GET", QRZSUBSURL+"?s=" + Thisform.qrz_session +";callsign="+m.cCall, .F.)
<?xml version="1.0" encoding="utf-8" ?>
<QRZDatabase version="1.36" xmlns="http://xmldata.qrz.com">
<Callsign>
<call>WN4AZY</call>
<aliases>WB4AZY</aliases>
<dxcc>291</dxcc>
<fname>DENNIS L</fname>
<name>HEVENER</name>
<addr1>1323 CENTER DR</addr1>
<addr2>AUBURN</addr2>
<state>GA</state>
<zip>30011-3318</zip>
<country>United States</country>
<lat>33.993628</lat>
<lon>-83.723097</lon>
<grid>EM83dx</grid>
<county>Barrow</county>
<ccode>271</ccode>
<fips>13013</fips>
<land>United States</land>
<efdate>2018-04-17</efdate>
<expdate>2028-06-09</expdate>
<class>E</class>
<codes>HAI</codes>
<u_views>3953</u_views>
<bio>24</bio>
<biodate>2015-12-06 14:38:22</biodate>
<moddate>2019-04-17 18:15:56</moddate>
<MSA>0520</MSA>
<AreaCode>770</AreaCode>
<TimeZone>Eastern</TimeZone>
<GMTOffset>-5</GMTOffset>
<DST>Y</DST>
<eqsl>0</eqsl>
<mqsl>1</mqsl>
<born>1958</born>
<lotw>1</lotw>
<geoloc>geocode</geoloc>
<name_fmt>DENNIS L HEVENER</name_fmt>
<serial>707541</serial>
</Callsign>
<Session>
<Key>69ec08ac46ffe818051fd7ea57556759</Key>
<Count>12692</Count>
<SubExp>Sun Feb 27 00:00:00 2028</SubExp>
<GMTime>Mon Nov 16 23:25:37 2026</GMTime>
<Remark>cpu: 0.010s</Remark>
</Session>
</QRZDatabase>
Then I get the BIO info:
.oXML.Open("GET", QRZSUBSURL+"?s=" + Thisform.qrz_session +";bio="+m.cCall, .F.)
<Bio>
<call>WN4AZY</call>
<size>0</size>
<bio>http://www.qrz.com/xml/current/?s=69ec08ac46ffe818051fd7ea57556759&amp;html=WN4AZY</bio>
<modified>2015-06-17 18:19:57</modified>
</Bio>
<Session>
<Count>12670</Count>
<GMTime>Mon Nov 16 22:37:23 2026</GMTime>
<Remark>cpu: 0.007s</Remark>
</Session>
</QRZDatabase>
The URL to get the Bio info is not https. I forced it to https but am getting a different error:
Error opening https://www.qrz.com/xml/...7556759&html=WN4AZY
OLE IDispatch exception code 0 from msxml6.dll: The operation has been canceled ..
But if I paste the URL in a browser, it works. I suspect that the server is looking at the header info from my GET and sees that it is not an actual browser, and cancels the request. There is a way to fake it -- have to find the code. Or maybe I will just provide a link in LOGic and not bother displaying the bio info.
Meanwhile, uncheck Display Bio in Setup. It doesn't seem to care whether the main lookup is https or not. Just the bio lookup. That explains why some calls work and others don't. They error only if the call has BIO info.
