Hi Dennis...lately I'm seeing this error when the callbook window does an auto lookup on QRZ. "Error opening
http://www.qrz.com/xml/c...c11feafd&html=FR5CN
OLE IDispatch exception code 0 from msxml6.dll: The HTTP redirect request failed "
This is the response I received from a QRZ trouble ticket, which means absolutely nothing to me:
"<p> You should be using the HTTPS endpoint, not HTTP. For some reason your system is refusing the redirect which would handle the change automatically. You need to update your XML endpoint manually as a result.</p> <p> </p>"
So, is this a LOGic problem, or a QRZ problem?
