XML lookup with QRZ
#1 Posted : Friday, November 13, 2026 2:20:45 PM(UTC)
Was thanked: 160 time(s) in 142 post(s)
Hi Dennis...lately I'm seeing this error when the callbook window does an auto lookup on QRZ. "Error opening http://www.qrz.com/xml/c...c11feafd&html=FR5CN
OLE IDispatch exception code 0 from msxml6.dll: The HTTP redirect request failed "
This is the response I received from a QRZ trouble ticket, which means absolutely nothing to me:
"<p> You should be using the HTTPS endpoint, not HTTP.&nbsp; For some reason your system is refusing the redirect which would handle the change automatically.&nbsp; You need to update your XML endpoint manually as a result.</p> <p> &nbsp;</p>"
So, is this a LOGic problem, or a QRZ problem?
#2 Posted : Friday, November 13, 2026 6:56:51 PM(UTC)
Same error I get but not on all calls
