K8ZM;13172 wrote:This feature was added several years ago but dont think it was ever finished. I had all the changes implemented long ago re-GRID, FFMA, Grid field Size, etc, etc. Here's what works and what doesnt;
Progress 2 for Grid and Progress List: works
Progress for FFMA (Main): Ignores all multi-grid QSO's
Awards Report for Grid: Ignores the 2nd grid for all multi-grid QSO's
Awards Report for FFMA: Ignores all multi-grid QSO's
Really would appreciate a fix for these, keeping track manually of multi-grid qso's continues to be more than a tedious task.
Trying to filter the log on the 1st grid in the field works but returns nothing if trying to filter on the second grid.
Thanks, Brad K8ZM
If you can get the reports to work by keeping the Multi-Grids in the GRID field as they are now that would work for me, although not ideal as other apps like ClubLog and GridTracker are looking for VUCC_GRIDS I can at least export and edit the adif file.
Leaving the GRID field as is its halfway there....the Awards Progress List and Progress 2 picks up the Multi-Grids as it should. I found that I didn't have the comma delimiter enabled in Awards Tracking for FFMA and thats why above I said Progress for FFMA (Main) was ignoring all mult-grid QSO's.
That leaves the Awards Report for GRID which Ignores the 2nd grid in multi-grid QSO's and the Awards Report for FFMA which totally ignores all multi-grid QSO's.
I think the only other issue was with LoTW downloads where when the list downloads the GRID column/field is blank for any multi-grid QSO's (see threads above where I have a pic).
Okay, done for now.....think I posted enough for a bit
Note: If under the ADIF tab in Log Fields you check the box to Export the ADIF field FFMA, that field is populated and Exported for EVERY QSO, i.e., it doesnt get populated for 6m QSO's only, it gets populated for every QSO exported.
