FOC import not working
The URL is
N5XZ on 1/27/2021(UTC)
Thanks, that worked.
WN4AZY on 1/27/2021(UTC)
K8ZM on 6/17/2026(UTC)
WN4AZY on 6/22/2026(UTC)
#7 Posted : Tuesday, June 23, 2026 7:03:42 PM(UTC)
It is there.
What I would like to do is have LOGic download from the site without having to manually download the file. You can edit the URL.
Let us know. Tnx.
#8 Posted : Thursday, July 2, 2026 6:11:31 PM(UTC)
Dennis, the new file is located at https://g4foc.org/wp-con.../tylerdata/All_Time.txt . Of course, one must be an FOC member to access it. As you can see it is a text file, not zip. The program is looking to unzip a file, so it won't work. If I can find a zip file online, I'll let you know.
FOC_All_Time.txt (104kb) downloaded 12 time(s).
#10 Posted : Saturday, July 4, 2026 11:16:49 AM(UTC)
Was thanked: 154 time(s) in 137 post(s)
will it work if you zip it?
Doug W5GA
#11 Posted : Saturday, July 4, 2026 3:25:19 PM(UTC)
Doug W5GA
I haven't tried it yet.
#12 Posted : Sunday, July 5, 2026 2:34:13 PM(UTC)
Doug W5GA
I tried but I run into multiple errors.
Dennis?
#13 Posted : Friday, July 17, 2026 2:19:18 PM(UTC)
Dennis, see the FOC download in a previous post.
#9 Posted : Sunday, July 26, 2026 5:02:44 PM(UTC)
No sweat. I will pull out the unzipping code. Will be in the next release hopefully.
Could you tell me what the various columns are for?
The thrrd column has either I, F, or A
1 G6FO I Austin Forsyth 1947 1973-02
2 G2ZC I Fergie Houston-Fergus 1947 1957-01
3 GC8NO I Bob Postill 1947 1958
4 G3VM I F.W. Fisher 1947 1947
5 G5IH I G.C. Turner 1947 1954-01 ZB1IH
6 G8VG I Bill Windle 1947 1984-01
7 G5RV I Louis Varney 1947 2000-07 VK9LV,CX5RV
8 G2VV I Jim Roe 1947 1968-01
9 G6PJ I B. Pashley 1947 1954
10 VP7NI I David Mitchell 1947 1963 GW6AA,ZL1NP
11 G8PG I Gus Taylor 1947 2008-12 GW8PG
12 GM6RV I Bill Stirling 1947 1957-06
13 G2SO I Mal Geddes 1947 1997-05 ZE3JO,Z23JO
14 G5JP I C.J. Peach 1947 1949-08
15 G3BA I Tom Douglas 1947 1963
16 G3DQ I Cliffe Metcalfe 1947 1960-12
17 G8UT I Bert Challis 1947 1965-05
18 G2NM I Gerry Marcuse 1947 1961-05
19 G5JM I H.E. James 1947 1947
20 G4FN I Jack Wakeman 1947 1975-03
21 G2IO I Jack Lees 1947 1975-12
22 G3VA I Pat Hawker 1947 1951-10
#14 Posted : Monday, July 27, 2026 2:15:08 AM(UTC)
Dennis, I'm not sure. I woudl guess
I = Inactive
F = Full
A = Associate member
WN4AZY on 7/28/2026(UTC)
#15 Posted : Wednesday, August 12, 2026 10:48:16 PM(UTC)
Dennis, any progress on this?
Guest (10)
