LoTW Import Error Messages
#1 Posted : Wednesday, May 20, 2026 5:21:06 PM(UTC)
Was thanked: 78 time(s) in 73 post(s)
OK Dennis, what do these mean? It's not possible that I had no LoTW credits to download.
Screenshot 2026-05-20 171249.png (45kb) downloaded 17 time(s).
Screenshot 2026-05-20 171342.png (50kb) downloaded 7 time(s).
Screenshot 2026-05-20 171413.png (44kb) downloaded 7 time(s).
Screenshot 2026-05-20 171443.png (41kb) downloaded 5 time(s).
Screenshot 2026-05-20 171506.png (22kb) downloaded 8 time(s).
WN4AZY on 5/20/2026(UTC)
#2 Posted : Wednesday, May 20, 2026 5:50:20 PM(UTC)
Was thanked: 533 time(s) in 446 post(s)
Am aware of the problem.
https://www.hosenose.com...nload-from-Eqsl-cc.aspx
Working on it.
#3 Posted : Thursday, May 21, 2026 5:48:14 PM(UTC)
Working on it.
Thanks, Dennis. Just to be clear, my problems were with LoTW, not eQSL.
#4 Posted : Wednesday, May 27, 2026 12:01:05 PM(UTC)
Working on it.
Dennis, any update on this issue? I am not able to download my LoTW credits. Please advise.
Anyone else having this issue??
#5 Posted : Monday, June 1, 2026 3:23:28 AM(UTC)
What I have determined is that somehow LOGic loses the date: "Download QSLs on or since ... ". After adding a date to this field, the download works.
Dennis, do you know why LOGic would lose this date information???
Screenshot 2026-06-01 032409.png (23kb) downloaded 5 time(s).
WN4AZY on 6/5/2026(UTC)
#6 Posted : Friday, June 5, 2026 8:49:54 AM(UTC)
Don't know. Will look at it. Thanks.
N7IP
#7 Posted : Friday, June 5, 2026 2:11:21 PM(UTC)
After reloading Logic, I now hve this problem too. After awhile, I see "insuffient stack space"
If I fill in the "date after" fied, I get an OLE error.
Bob, N7IP
N7IP
#8 Posted : Sunday, June 14, 2026 7:09:45 PM(UTC)
Hi Dennis. Any estimate for how much longer this fix will take?
Thanks, Bob
#9 Posted : Monday, June 15, 2026 10:40:59 AM(UTC)
Ok, I fixed the OLE error reported in the original post. Please get the new 10.0.33 update (help/check for updates).
Sorry, could not reproduce this. Maybe the other errors were causing this? Try again with the .33 update and post here if problems continue.
If I fill in the "date after" field, I get an OLE error.
A couple updates ago we made it write to disk instead of RAM. Try again with the .33 update and post here if problems continue.
Sorry it took a while for this update. Family issues, and I ran into problems with Visual Studio, plus the changes are not minor. Should be back on track now. I realize there are other issues pending, but wanted to get this fix out. Thanks for your patience.
N7IP
#10 Posted : Monday, June 15, 2026 11:50:16 AM(UTC)
Dennis, update 33 did not solve this problem. See the screen shot attached.
Bob
WN4AZY on 6/16/2026(UTC)
#11 Posted : Monday, June 15, 2026 9:30:02 PM(UTC)
Bob
Bob, you're gonna have to enter in a date for "Download QSLs on or since". That's what mine kept losing, too. You'll have to go back to see the last download from LoTW and enter that date. PITA
#12 Posted : Tuesday, June 16, 2026 5:03:12 AM(UTC)
Sorry guys. Not seeing a problem here.
Go ahead and enter the date manually the first time. Or leave it blank to download everything. Proceed with the download. When the download completes, go back to the main page. Today's date should be filled in there. It should remember that date even if you exit LOGic and return.
I also tried manually entering a date. 1/1/26. I didn't actually do any download. But I exited the form, exited LOGic, and came back. 1/1/26 was still there. I couldn't make this fail. I entered 6/7/26, did not tab out of the field, and closed LOGic. My date stuck.
In other words, here are the rules LOGic follows:
1. Any date, including a blank date, will be remembered when you exit the form.
2. The date will be updated to today's date after completing a download.
If that isn't happening, I can log in and take a look.
If you want to proceed to troubleshoot on your own:
The date is stored in your LOGDATA folder in stationinfo.ini. Look for APP_LOTW_LASTQSL under the [LoTW] section header.
Try editing stationinfo.ini by hand. Use Notepad or any text editor. Make the line under [LoTW] look like this:
APP_LoTW_LASTQSL=20260607
If the line is already there, change the date. Save your changes. If you get an error when trying to save, you have a permissions problem. Manually saving MAY fix the problem.
When you go into LOGic, 6/7/26 or whatever date you put in stationinfo.ini should appear.
DH WN4AZY
