FT2 digimode
#1 Posted : Monday, March 2, 2026 2:19:55 PM(UTC)
are there news about Logic settings to import or export without problems?
Digital software are running in right mode to save the qsos's into Logic via UDP referring FT2 after mode window update.
Any idea or its right to standby the standard resolutions? Thanks.
Ciao Dennis from Italy.
#2 Posted : Monday, March 2, 2026 4:15:38 PM(UTC)
Hi Mauro:
I am not aware of any problem with LOGic's import or export. Please describe any issues you are having.
I am not familiar with any FT2 software. WSJT-X and other similar digital communications programs use an intermediate ADIF file. Is this a possibility with FT2?
Could you provide a link to the software you are using?
Thanks for hosting an excellent Winter Olympics games!
#3 Posted : Monday, March 2, 2026 5:31:01 PM(UTC)
Thanks for the quick reply.
I'm using Decodium 3.0 software, which is a derivative of Taylor's WSJT-x. The code appears to already be present in the original version but not implemented. FT2 allows QSOs with a maximum time of 11 seconds and a BW twice that of FT4.
This combination leads to a reduction in sensitivity, requiring higher power and/or a better signal.
Regardless, Decodium communicates with Logic, and once the QSO is over, I have all the data in my logbook with the FT2 description.
I've updated the mode setup table as you can see in the attached screenshot.
My problem starts when I send QSOs to eqsl.cc, which I can't do.
However, with LoTW, after modifying the Tqsl certificate, the QSOs are accepted and described as DATA only.
It's true that I've received confirmation from eqsl.cc with the MFSK (FT2) description, but I haven't been able to reproduce the typology.
The Decodium software can always be found with the latest update at:
www.ft2.it
I hope my explanations were helpful.
Let me know, thank you in advance.
Mauro IK0CHU
Screen Shot 03-02-26 at 11.18 PM.PNG (7kb) downloaded 2 time(s).
Screen Shot 03-02-26 at 11.17 PM.PNG (308kb) downloaded 2 time(s).
