Logic 9 install and Radio Interface setup problems
WD4ASP
#1 Posted : Wednesday, February 22, 2012 10:35:59 PM(UTC)
I got the following error when installing Logic 9:
Error #1806
Msg: SQL: Column 'CALLSIGN' is not found.
Line # in .\UPDATES\RUNONCE_TABLES.PRG':262
Code:
I continued the install and the rest of it went smoothly. Do I need to be concerned about this error?
I then ran Logic 9 and when setting up the Radio Interfaces I got the following error:
Class definition ICOM735, ALSO OMNI-VI is not found.
I exited the program and restarted it and got the following msg:
Error 1733 "Class definition ICOM735, ALSO OMNI-VI is not found" has occurred in program LOGICAPP.LOAD_RADIOS, line 54
Attempt to continue?
I answered Yes.
I set up my FT-736R radio interface without any problem and it appears to be working.
Fred
#2 Posted : Wednesday, February 29, 2012 6:07:58 PM(UTC)
The error from RUNONCE_TABLES is nothing to worry about.
For the Icom735, use the new non-legacy driver ICOM BASIC. (the .038 update should fix the CLASS NOT FOUND error if you need to use the old drivers for some reason.
This page was generated in 0.016 seconds.
