Posts: 365 Location: Missouri
Thanks: 67 times Was thanked: 111 time(s) in 98 post(s)
Dennis, is there a way to have Logic report unworked entities (and ONLY unworked entities. Having unworked along with the rest of what I have worked isn't what I'm looking for) on a per band and/or per mode basis?
Groups: Administrators, Beta Testers Posts: 3,061 Location: Auburn, GA Thanks: 974 times Was thanked: 486 time(s) in 401 post(s)
You can filter the select criteria on the Awards report. Change the default select criteria QSL_RCVD $ "SFRWU"
to QSL_RCVD $ "U"
There is a little writeup about it in the run report form. You have to scroll down.
Don't overlook the CARDS NEEDED FOR AWARD report also. Very handy.
OK, tried what you suggested (QSL_RCVD $ "SFRWU" to QSL_RCVD $ "U"), and Logic tells me there is nothing to report. In fact, I tried a couple different variations, and got the same message. Did I just find a bug?
No, it definitely works. I think you need to go thru NEXT NEXT NEXT on the opening dialog and checkmark PRINT UNWORKED ENTITIES. (You had to have done that to get U printed as you described in your orig post).
Got it. I hadn't checked the print unworked entities box...works better if you do that!
Many thanks!
