Groups: Administrators, Beta Testers Posts: 3,209  Location: Auburn, GA Thanks: 1104 times Was thanked: 532 time(s) in 445 post(s)
No, there is no setting. If it is open when you close LOGic, it should reopen when you start LOGic the next time.
This is all stored in FORM.INI. Start LOGic, make sure Telnet 1 is open, then close the program. Open it in Notepad and look for the [ENVIRONMENT] section. Under that you should see
Telnet1=Yes
If it says NO, then something isn't getting saved properly. Change it to Yes then it may open automatically for you.
ALSO, after you restart LOGic, look in the WINDOW menu. It could be that it is open and hiding behind something else.
Let us know what you find.
